We have a Varian Prostar 230 inert pump. The outlet check valve filter has a yellow ring around the outside unlike the non-inert filter. Can anyone help with how to replace the filter in the inert model. Any detailed instructions with part numbers required would be much appreciated. It appears like the filter cannot be removed like with the non-inert filter which has a retainer holding it in place.
