System suitability enabled by default
Can I somehow set EMP3 in a way where "Calculate system suitability" would be checked by default (also for void volume).
Perhaps with a default processing method that would contain those two parameters?
Yes DavidHPLC, as you say you could create a template project with your required methods (instrument, processing and method sets) and have all these with the system suit options ticked and void volume completed. Then when you create a new project you can take your methods from this project.
