GCIRMS
Posted: Wed Mar 19, 2008 12:00 pm
Hello!!
I have a problem with a ThermoFinnigan GC -IRMS, it is not working anymore, because of the low pressure, it cannot reach the setpoint pressure. First of all, I searched for leaks otuside from the instrument to all connections, but is was ok, no leaks also to the column, I changed the oil to the pump, may be it was not working properly..but still the same problem. Is anyone have any idea of something else, to try find out where is the problem and fix it?
Thank you in advance
bsxenia
bsxenia
