Do-not-inject list
Posted: Mon Mar 17, 2008 7:30 pm
One of my biggest challenges in managing this lab is trying to figure out the compatibility of the analytical instruments we have with the wide range of chemistry that is being investigated by the various research groups at the university.
I never know if it is okay to inject something on the column (GC-FID and MS mostly) or not. The fact that most of the chemistry is catalytic also means that the samples typically contain inorganics like Ru, Pd, Cr, Au catalysts that are typically involatile, as well as bases such as potassium carbonate.
We also analyze 96-well plates and the concentrations are typically low. Our inlets are equipped with glass fiber (and hopefully that can trap most of the involatiles) - when faced with 96-well samples, it often becomes impractical to filter out residues (and the commercial filter plates are not an option for us given their cost).
Are there certain components that one should ABSOLUTELY NOT inject unto the instruments? We currently do not have guard columns installed (it's on the list when we get more money!) so that is also an issue that worries me when looking at all those involatile inorganic catalysts!
Are bases that much of a problem? At what pH does it become an issue (we have typical HP-1 (1ms) columns at the moment)...?
Basically just looking for hints, tips and ideas as everytime someone comes in, I'm never quite sure how to look at it. But I would definitely like to preserve the instruments' integrity for the greater good of the lab!
Thank you!
Roxanne.
Thank you!
Roxanne.
