Reduction of resolution between two chemical entity
Posted: Sun Mar 16, 2008 12:14 pm
Dear All
Nice to see all of you on this forum. I want some experts views for reduction of the resolution bewtween two drug molecules.
I am using mobile phase Phosphate buffer 25 mM pH7.0 with 0.1% Triethylamine:Acetonitrile(52:48%v/v) with C18 (250 X 4.6 5 micron) column. The flow rate is 1.0ml/min with column tempe.25C.
As i am developing the simultaneous method for two drugs. One drug molecule is eluting at 5.0 min and another is at 18.6min. There is difference of around 13.0 min between theses two drugs.
Can any one suggest how i can reduce this 13min difference between these two molecule and also my aim first drug should come elute more than 6.0 min.
Also the total run time of system should not exceed more than 20min.
If i will use the Acetonitrile methanol mixture is it will be useful ?
Kidly give your valubale suggestion.
Thank you in advanced.
