Analysis of formaldehyde in a injectable formulation
Posted: Thu Mar 13, 2008 8:22 am
Hi everybody,
we have to analyze the contents of formaldehyde in a injectable formulation. The product can contain up to 5% of formaldehyde. The formaldehyde is an hydrolysis product of the active compound.
The active is dissolved in water and after dissolution it produce an impurity and formaldehyde.
At acidic pH the rate of formation of formaldehyde increase but at basic pH the rate decrease.
We have searched for some methods of analysis of formaldehyde but the major part of the derivatization work in acidic media..
We have the problem to analyze the content of formaldehyde in the product and we need conditions that doesn't produce formaldehyde.
We have tried to derivatize formaldehyde with PFBHA and quantify it with HS-GC but we are not sure that we aren't creating formaldehyde..
Do you have some experience with analysis of aldehydes?
Do you have some cue to our problem?
Thanks in advance for the answer,
Have a good day!
Have a good day!
