Working in column limits
Posted: Wed Mar 05, 2008 11:48 am
(sorry if the topic sounds abstract…
Hi
All the columns come with its own pre-described limits on pH, temperature and back pressure (mechanical stability). So is it advisable to work on the end points on these limits, let say for eg. A column says its stable for a pH range on 2-8, so can safely work at pH 2 or 8..and in case of back pressure if the limit is 275 bar can I have work on 250 0r 240 bar?
if so any precautions and how long can i work in such conditions
Thank you
Hi
Thank you
