ghost peak at LC
Posted: Sat Dec 23, 2017 8:13 pm
I ran monoamine detection with HPLC-ECD.
I continuously saw monoamine peaks when I loaded buffer only (without any monoamine powder to setup the standard quantification). The HPLC water, Ringer sand mobile phase do not show any peaks. However, When I load stock and dilution buffer only, I see the monoamine peaks at the correct time points. I really don't understand why the monoamine peaks appear at the chromatogram even I did not load microdialysate or monoamine powders.
Would you give any clues to solve this problem?
