PDA spectrum of compound- 2nd derivative?
Posted: Sat Dec 23, 2017 1:50 pm
When running a degradant sample on the PDA Detector, can you put much store in the second derivative view? Example: I have a peak that could be my active but degrading or breaking down somehow *6 months 40 degree sample*. The UV spectrum of the peak is not like the usual active UV spectrum BUT when you look at the 2nd, 3rd and 4th derivative the lamba max value is there.
Does this suggest that the active peak is there somewhere but is just degrading? Some people have said that 2nd derivative means nothing and that if you don't get the distinctive uv spectrum shape from the 1st derivative you cant make any assumptions. Thoughts?
