Does kinked tubing cause dipping baselines?
Posted: Sat Dec 16, 2017 11:46 am
I run a complex method on Waters binary UPLC which requires me to insert a small C18 column between the Aqueous line and the mixer inlet, to trap ghost peaks before they reach the column. Now this obviously needs I have to bend and kink the tubes a bit so they can all fit and I can close the door on the BSM, which is particularly bent for the "mixer outlet to column inlet" tubing which runs up the length of the instrument to the 6 port loop and column valve.
I have noticed the last few runs have odd dips in the baseline or at the start of the gradient run the basline jumps up then 2 mins later back to normal, which Empower sees as a series of peaks. Could the tubing be causing this? I use high quality solvents.
