Double void peak for water??
Posted: Tue Feb 26, 2008 5:21 pm
Hi all,
I am running water blanks on a polymeric SCX column with a steep NaCl gradient in 20mM MES, and I keep getting a double peak right at the end of my isocratic stage (0-1.5min). (gradient: 100mM to 750mM NaCl in 4.5 minutes, after 1.5 min isocratic 100mM). I don't understand why HPLC grade water would give a double peak...?
I am new to HPLC, so don't hesitate to state the obvious...
