splitting peaks with direct SPME
Posted: Fri Feb 22, 2008 9:33 am
I am using direct SPME for sampling, but sometimes the peaks in the beginning of the chromatogram split into two peaks. I am sure this concerns the same compound. I also had this problem once with thermal desorption of SBSE. Does somebody know what might be the problem??
In the same chromatogram where peaks were splitting, the peak area were much higher than in other samples (while it was the same concentration). Actually I really don't know what went wrong.
Thanks!
Thanks!
