Custom field search-Result Set Only
Posted: Fri Dec 08, 2017 4:37 pm
If the search order of a custom field is set to Result Set Only and you open up your sample set, review injections, and there is a blank cell under the custom field name, is that because you haven't processed a result yet and therefore there is no result to report?
Because in other runs in my project I can see a value for the custom field even when in sample set review mode but I'm guessing its just taking a result from a result set and not the actual current injections I have reviewed?
