HPLC high back pressure problem from newbie
Posted: Fri Feb 15, 2008 1:10 am
Hi Everyone...
I am quite inexperienced with the HPLC and hope to get some suggestions/advice.
We have a Waters 2659 system and it is giving me very high back pressure. I unhooked the column, then guard column and the pressure is still very high. I then changed out the inline filter, and still very high. 0.5ml/min was just water was around 800-900 psi.
The hplc was mainly used to separate proteins using size exlusion column. Isocratic flow with 50% acetronitrile and 50% TFA(0.1%). UV detector is used.
I am not sure if I need to or is able to provide anymore details. I hope that someone can provide some advice on where to start looking for the problem.
Thank you very much!!
