Do you have some suggests for Tadalafil impurities in USP ?
Posted: Wed Nov 29, 2017 9:03 am
I'm following the procedure of USP about the Tadalafil organic impurities.
In the below control and situation:
Mode : LC
Wavelength : 285 nm
Flow rate : 1.0 mL/min
Injection volume : 20 micro-liter
Column : 4.6-mm X 25-cm; 5-micrometer packing L7
I don't know which peak is we-wanted.
Do you have any suggest or spectrum for me to referring?
Thanks.
Mode : LC
Wavelength : 285 nm
Thanks.
