how we can prepare holium perchlorate solution
Posted: Tue Feb 12, 2008 4:37 pm
by kishore1984
regarding:
whether its has any affect to sunlight...
[/img]
Posted: Tue Feb 12, 2008 6:06 pm
by JGK
thank you,
Posted: Wed Feb 13, 2008 4:47 am
by kishore1984
but while am preparing the solution it was changing its color.... is there any intetrference with light?
quote="JGK"]Some info here:
http://www.starna.co.uk/ukhome/faqdatasheet/MSDS-HL.HTM[/quote]
Posted: Thu Feb 14, 2008 12:40 am
by Peggsy
why not do a small experiment, prepare it in the dark at room temp, see if the color change is still evident, maybe even try in the dark at a lower temp (say 4C) to check for temperature effects.
sounds like fun! if you do this, please report your observations back here
peggsy
sir
Posted: Fri Feb 15, 2008 5:27 pm
by kishore1984
i did that experiment in a closed room ther it doesnt change its colour when i went outside its changes its color.. wat the reason for changing the color
Posted: Mon Feb 18, 2008 12:48 am
by Peggsy
how did you prepare your solution, what grade are the reagents that were used?
This solution would seem to be quite stable from what i can find on the web (google and lit searches). I am unfamiliar with this solution, what is the exact color change that occurs? Nice challenge indeed.
Posted: Mon Feb 18, 2008 4:53 pm
by kishore1984
the color is pale white in color first and changes to slight pink based on the light ....
Posted: Tue Feb 19, 2008 2:01 am
by Peggsy
how did you prepare your solution, what grade are the reagents (solvents included) that were used?
