chemstation peak symmetry vs USP tailing
Posted: Mon Feb 11, 2008 3:27 pm
The EP recommends that the tailing factor should be between 0.8 and 1.5.
Is there a way to put the EP/USP tailing factor into a custom report (as the extended performance report is very long), or is there an easy conversion from chemstation’s symmetry factor to EP/USP tailing factor, so I can apply the EP limits?
