more peak resolutions
Posted: Sat Feb 09, 2008 12:22 am
Hi could anyone possibly help me with this problem?
A chromatographic column 4.0 metres long is known to have the following Van Deemter coefficients; A = 0.12 cm, B = 0.34 cm2s-1, C = 4.1 x 10-2s. It is operated at a flow rate of 3 cm s-1. Three peaks emerge when a hydrocarbon sample is injected;
Component Retention time / s peak height / cm
1 350 4
2 470 8
3 540 1
(a) Calculate the column parameters, peak widths and resolutions between each pair of peaks
I have calculated H to be 0.3563 making N=1122, and tr/w=8.38.
I now need to calculate the resolutions between each pair of peaks?
can anyone explain to me how to do this
cheers mark
1 350 4
2 470 8
3 540 1
cheers mark
