removing/avoiding dissolved silica when extractingTLC plates
Posted: Fri Feb 08, 2008 11:53 pm
RE: Any clues or hints to removing or avoiding dissolved silica from TLC plate extracts?
We analyze anionic oligosaccharides that need aquous buffers for good resolution - typically silica gel G TLC plates developed with n-butanol/acetic acid/water in 3:1:1 to 1:1:1: ratios give great resolution of the various size sugars as well as some epimers. We do semi-preparative clean-up of some compounds by eluting the silica w/ target bands with water after air-drying the Al-backed plate ...we cannot use straight MeOH, EtOH or non-polar solvents to extract these sugars for solubility reasons. However, we typically get some silica residue in our final extracted samples (even though extensively centrifuged before lyophilization) & sometimes this hurts our enzyme-based steps later on.
As a 'semi-solution to the problem', we have added a Na-based buffer (phosphate or Cl salt) to resuspend the dried residues hoping that insoluble Na silicate would be formed which we could remove later by centrifugation, filtration...it works to a certain degree, but sometimes we need salt-free conditions, or its effectiveness is sporadic etc. (The amount of silica removed may be controlled by how long we dry the plate > the water extraction may be more acidic if not as dry, etc, but not tracked down).
We are sure the insoluble residue is not our sugars & our solvents are HPLC grade. Did not if Si by elemental test, etc
Any clues or hints to removing or avoiding dissolved silica?
Thank you for your time & consideration,
All the best,
Paul
All the best,
Paul
