nagetive peak in USP method
Posted: Fri Feb 01, 2008 8:16 am
Hello everyone:
We are determining related substance of the capecitabine API by HPLC which is USP method, now we found a nagetive peak just before at a related substance peak(RT=2.7min), it disturb the quatity for the impurity.the mobile phase is water(containing 0.1 glacial acetic acid):methanol:ACN=60:35:5, column is C18 4.6*250mm, 5u; diluted solution is water:methanol:ACN=60:35:5,we adjusted the mobile phase, change the source of water, methanol, ACN, acetic acid(they are all HPLC grade), but all cannot remove the nagetive peak. Finally, we change the diluted solution to water:(methanol:ACN=35:5)=9:1, the nagetive peak is almost disappeared. Because the method is USP method, so we don't know weather it is permitted by FDA. What should be done if we change the diluted solution? We should validat the whole method? And how can we eliminate the nagetive peak?
Wish your help.Thanks of all.
Zhengmin
2008.2.1
Zhengmin
2008.2.1
