relationship between area count and retention time
Posted: Thu Jan 31, 2008 11:53 pm
Have you had discussed this?
Flow is contant. By changing organic percentage, we can move analyte around, such as from 3 to 6 minutes. The question is what happens to the UV area counts? The same or change?
IF change, due to solvent or detector effects?
