What causes MS shutdown after 18min?
Posted: Thu Jan 31, 2008 5:35 pm
by wl_yang
Agilent 6890GC/5973MSD
The MS automatically shut down after 18 min. Could you please help me figure out the possible reasons?
Thanks a lot.
Posted: Thu Jan 31, 2008 5:53 pm
by Schmitty
Is the power to the MS getting turned off/is it venting?
Or, is the data not getting collected after 18 minutes?
If it is just not collecting, but the GC continues to run, you probably have a "Detector Off" time of 18 minutes under MS Parameters.
Are there any errors in the log?
Posted: Fri Feb 01, 2008 2:17 am
by AICMM
wl_yang,
You have a leak and the turbo is not getting up to speed in the specified time.
Best regards.
Posted: Fri Feb 01, 2008 9:30 am
by Peter Apps
How often has this happened ? Does it always happen at the same time during a run ?
