relationship between area count and retention time
Have you had discussed this?
Flow is contant. By changing organic percentage, we can move analyte around, such as from 3 to 6 minutes. The question is what happens to the UV area counts? The same or change?
IF change, due to solvent or detector effects?
Excel
Hi ym3142,
We’ve discussed a similar topic recently. So you’ll get the short version: The area should remain constant.
If not? The change could be due to solvent induced max. wavelength shift or absorption coefficient.
In total there are 23 users online :: 1 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 22 guests
