solvent for acrolein
Posted: Tue Jan 29, 2008 6:53 pm
by Grace2007
Hello everyone,
I try to find a proper solvent to make acrolein standard solution for GCMS.
I know most people use methonal or ethanol but these solvents are not suitable for my purpose. I want to try benzene, hexane, toluene etc.
Does anyone know if acrolein can be dissoved in benzene, hexane or toluene?
thanks,
grace
Posted: Tue Jan 29, 2008 7:02 pm
by a2j812
I purchase an acrolein standard from a local supplier and it comes in water. Of course the largest drawback to that is that you have to be careful of the temp at which you store it.
Posted: Tue Jan 29, 2008 7:10 pm
by Grace2007
Thanks for your reply!
storage is not a problem. we have a fridge. my column is Restek RTX-1, and my start temperature is 35C. I don't know if I can try water.
Grace
Posted: Wed Jan 30, 2008 8:02 am
by Peter Apps
Injecting water onto a GC can cause all sorts of problems. If you google acrolein you will very probably find what it is soluble in.
Posted: Wed Jan 30, 2008 2:38 pm
by JI2002
What's the method you use for acrolein analysis?
Posted: Wed Jan 30, 2008 2:55 pm
by chromatographer1
Propenal solubility?
I would suggest dioxane or ispropyl ether.
Benzyl alcohol?
best wishes,
Posted: Wed Jan 30, 2008 11:03 pm
by AICMM
Ethyl acetate, ethyl ether, probably DMSO if you want a reallyheavy solvent......
Best regards.
Posted: Thu Jan 31, 2008 1:56 pm
by Grace2007
Thank all of you!
I will consider all your helpful suggestions and try.
Grace
