How much validation is required?
Posted: Sun Jan 27, 2008 3:13 pm
Opinions requested: How much validation is required?
I've been using a validated isocratic HPLC-UV method for over 20 years (on Type A RP-18, that's what was available then) with an OTC pharmaceutical product . It may turn out that we may need to assay for a new material as well, which also would use HPLC-UV. Because the polarities of the two analytes are so different, we would need to use a gradient (with the same column, same mobile phases, same flow rate), just starting with lower percentage of organic, to assay for both components in a single run. I'm thinking that this is not a major change, sample preparation would be the same, the only change would be to use a gradient instead of isocratic. The new component would not be an active, just for internal QC use. I'm hoping all I'd need to do would be to assay a few samples both ways, document equivalent results, and write a letter to the file, and term this tweaking. Any thoughts what the FDA might think? Surely they understand that much about chromatography. Don't say to ask my QA department because they feel that if one sneezes one time, that one must sneeze every time or that's a change.
