expected life/temp limits of methyl-deactivated cap. tubing
Posted: Tue Jan 22, 2008 9:00 pm
we are currently using a metal column on our GC for better hi-temp stability (our method tops out at 380C for 10 mins.) our baseline rose relatively quickly with the fused silica column.
i have a question with regard to the methyl-deactivated capillary tubing we are using as a guard column. This is also metal tubing, as per varian recommendation.
It appears that methyl-deactivated fused silica is quite a bit more cost-effective, but i am concerned about its ultimate life at this temperature.
I guess what i'm getting at, is that since the tubing is deactivated, will the breakdown that normally occurs at high temperature with fused silica actually affect our results if its only used as a guard?
thanks in advance!
thanks in advance!
