Limit of Free Salicylic Acid USP Test
Posted: Tue Jan 22, 2008 6:59 pm
Does anyone have experience with the Limit of Free Salicylic Acid USP Test?
1. I can not find the USP specified column dimensions ANYWHERE. It is a C-18 (L1) 5-µm 300 x 4.6mm column. Does anyone sell a C18 with these dimensions anymore? Would a special packed column take weeks to get?
2. Using the same column as used for last year's test (L1 10-µm 300 x 3.9mm column), my sample is at 130% label claim. But, the USP reference standard solution peak areas are similar to that seen last year.
3. Is the column internal diameter and micron size so critical that two peaks could coelute in this test? Last year's test did not show any small, closely eluting peaks that would interfere this year's sample.
As always, any answers or wisdom imparted on this subject would be greatly appreciated.
