Dionex LC25 chromatography peak problem
Posted: Wed Jan 16, 2008 1:06 pm
HI guys,
I am experiencing a problem with Dionex LC 25 system for peaks. After loading a sample through an autosampler, the baseline is not normal and straight rather gives ripples throught the run and the peaks as well is not in baseline main baseline format but also surrounded by ripples and i am not able to get the retention time for any of these peaks. Guys Please help me out.
Thank you.
Thank you.
