Empower Custom Field Query
Posted: Wed Jan 09, 2008 4:23 pm
I'm hoping someone can help me!!
I am running a simple assay as follows:
Std A
Sample X W1
Sample X W2
Std B
I can work out the amount for the samples - and other calculations.
I can also work out the average peak area for Std A and B.
But where my problem lies is with Normalised Area for the standards.
The procedure is looking for the % RSD of normalised area.
I have created a peak based custom field which is simply the peak area of standard A multiplied by the dilution (which is added in the run sample table) and I have called it NormalisedArea_A.
I have then done the same for standard B.
The results of these calculations are fine and correct.
The trouble starts when I try to calculate the % RSD. I cannot do this by component summary as there are two components.
I have tried to combine the custom field for the calculation - in other words apply the custom field for normalised area to both standards and when I do this I only get the correct answer for standard A but not B. I was hoping this would work, so I could use component summary to calculate the % RSD.
I then tried to create a result field based on the % RSD function in empower, however no matter what combination of the peak custom fields for NormalisedArea_A and NormalisedArea_B I use I cannot generated an answer.
It is possible that I am missing a bracket or a dot or something simple, but if anyone can shed some light on this I would be delighted.
Marion
Std A
Sample X W1
Sample X W2
Std B
Marion
