Deteriorated working standards
Posted: Tue Jan 08, 2008 9:29 am
by jbshan
Dear Friends
Can anyone tell what is a Deteriorated working standard :?: ...and how does it differ from our normal USP or other working standards.
what is the advantage of using it in method development
shan
Posted: Tue Jan 08, 2008 2:12 pm
by DR
If you're trying to develop a stability indicating method, it is a good idea to be certain that your method can discriminate between your main peak(s) and any known process impurities and likely degradation products.
Standard degradation via oxidation, heat, humidity, acid, base and light exposure is a common way to produce at least some of your primary degradation products and running these degraded standard portions is how you establish your method's specificity.
