Pump troubles
Posted: Thu Dec 27, 2007 9:29 pm
I am working a Thermo Surveyor LC system.
The pistons are moving, but no liquid is pumped. Even when I purged, nothing coming out. I disconnected the degasser outlet tubing and proportioning valve respectively, unrestricted flow was alright, which means liquid gets in pump head. I guess the problem is in the pump head. I suspect there is a big volume of air accidentally sucked in (someone else was using it and reported this problem to me). I do not know how to remove air. I tried drawing out by a syringe, but not quite sure from where to start. Do I need to open the pump head up? I am sort of reluctant to do that.
