peaks in blank plasma
Posted: Fri Dec 21, 2007 11:15 am
Dear group members,
I am developing the bioanalytical method for theophylline molecule on lc/ms/ms. I m facing problem with the peaks in blank plama. Even am getting 10 to 11 thousand area in blank. My mobile phase composition is ACN:0.1%HCOOH. flow rate adjusting from 0.8 to 1.0ml. pka of the molecule is 8.66. Am trying with different moble phase composition. My extraction method is LLE. Am using Tertiary butyl methyl ether (tried with diff solvents). only problem facing with the area in the blanks. Am not understanding why peaks are coming in the blank plasma.
Am i following the correct method ?
is there any method to over come peaks in blanks?
pl suggest me the right way to develop my method.
looking forward for your reply,
regards
chari
regards
chari
