Pulling RI info from NIST library searches following GCMS
Posted: Fri Dec 21, 2007 10:43 am
I'm running soem complex essential oil mixes by GCMS and routinely search the EI spectra against the NISt and Wiley 7 databases. I notice that if I use NISt MS Search (v2.0), that I can get a large list of Kovats Index RI information for candidate hits. However, for the compounds I'm searching (mostly terpenes), the returned list of Kovats index data can be in the hundreds, where each entry is a summary of user-contributed system information (column type, column class, active pahse, column length, etc) for the Kovats index value obtained. This list is too long to be browsed easily
What I would ideally like is to only look at the top 2 or 3 Kovats values that match most closely the column and conditions I am using. This would mean filtering the Kovats index list by inputtable criteria that would compare against the user-contibuted system information.
Has anyone worked out a way to do this?
thanks
Tony
thanks
Tony
