Test Mix for HILIC
Posted: Wed Dec 19, 2007 1:24 pm
Hello
I'm looking for a simple and convenient test mix for HILIC (Atlantis) columns for the purpose of performance check of the column over its lifetime.
(k' and N)
It should contain of a t0 marker and 2-3 substances which can isocratically separated.
Does anybody have something just by hand?
Thank you
Edit:
I'v googled a bit and found something at Alltech
Toluen, Hydantoin, Uracil, Caffein, Allantoin
ACN/NH4COOH pH3 95/5
sounds convenient to me and I have most of the substances in our lab.
I will give it a try.
As I've searched on the forum, toluen is a good choice for t0 marker isn't it? Or is naphthalen better?
(k' and N)
Thank you
Edit:
