Waters 2790 error state
Posted: Mon Dec 17, 2007 5:09 pm
I get "X axis Malfunction" shortly after sample drawn during an injection.
It was working this morning, but sometime over lunch it went wrong!
Manual - ever helpful - says "Check XYZ module connections" this I have done. Various cables appear to be plugged into sockets correctly. Specifically what shoudl I be looking for?
Any other things I should check before calling service? If I turn the 2790 off and back on again it homes itself without problem. The sample stage also aborts to home without problem, it's only during an injection that it is troublesome.
Many thanks for any advice !
