Is it possible to remove acetic acid with SPE in a wine?
Posted: Thu Dec 13, 2007 11:48 pm
I was thinking about this and the problems we had when first developing our acid profile here at the winery (12th and Maple Wine Company). We realized that if we didn't adjust the pH of the wine high enough that we would get poor retention of acetic acid. We originally started off just adding the wine straight onto a Restek SAX column and then realized that the pH of wine was below that of the pKa of acetic acid. (No makin' fun, I'm a genetics person, LC+SPE is totally new for me)
I was thinking that if there was a way to remove ONLY acetic acid from a wine with say a very large SPE column, 1-1/2 in diameter and 12 inches long that you could make Reverse Osmosis obsolete. Can anyone suggest someone who might like to collaborate on developing this type of method or suggest a current vendor of such things?
Thanks!
Thanks!
