Dionex Autosampler ASI 100 error
Posted: Thu Dec 13, 2007 5:51 pm
Hi.
I have been using my Dionex system with an ASI 100 autosampler for analyzing Melatonin in Phosphate Buffer. These are my operating conditions:
Solvents: 40:60 of acetonitrile and water.
Flow rate: 1 mL/min
Column Temperature: 30C
Injection volume: 30 microliters
Everything had been working fine for 4 months, until the autosampler arm suddenly got stuck. The error message was "vial pusher obstructed". I remember that on this day, I had run more than 15 samples on a stretch.
I tried changing the maximum vial height option to 53mm and it worked for a couple of days before getting stuck again. The needle moves to the sample vial, takes the sample and moves back to the needle port, but gets stuck while moving down towards the needle port. When I manually push the vial pusher down during this operation, the needle moves down to the port and injects the sample normally and everything works fine. However, for the next sample the arm gets stuck again.
Can you help me out with this? It would save me a lot of time, if I can get the autosampler to work again.
Flow rate: 1 mL/min
