internal standards in HPLC
Posted: Tue Nov 27, 2007 8:01 pm
I need some help in understanding the use of Internal standards and the use of them and what does it mean in the end.
I am working on AA in a revearse phase, Accq-tag method. and I am introducing internal Standard, noroleucine. I don't know much on the logistics with analyzing the internal standard. I will try to explain.
With one study I got about 20% difference lower of the nor internal standard, and I corrected it but one sample had a 60% difference it was corrected but what does that mean? Also I analyzed another study and it was completely different the 20% difference is higher on the other side the nor internal Standard.
Is there something wrong in the way I process the samples? Or is the internal standard the correction for that? Could some one explain a little, I feel I am doing something wrong?
Thanks Tracy
Thanks Tracy
