"Christmas tree" effect
Posted: Mon Sep 13, 2004 6:25 pm
by Urry
Dear colleagues,
Could you help me to overcome the “Christmas tree” effect I’ve got performing my GC/MS analyses. A sample injected usually consists of organic acid, amino acid and sugar TMS derivatives, pyridine and chloroform or acetonitrile instead of pyridine/chloroform. The injector (Optic) is programmed from 70 to 250 degrees, initial column (SPB50) temp is 70 degrees. After a number of runs I’ve started to observe the “Christmas tree” effect in peaks. The column replacement hasn’t helped.
Could anybody tell me what might be a reason of this effect and how to overcome it?
Thank you in advance,
Urry
Re: "Christmas tree" effect
Posted: Wed Oct 20, 2004 10:44 am
by Bernd
Hello Urry,
Chrismas tree is nice at the end of the year.. but not in chromatograms.
The reason why you see this may be in a to high injection speed, so that You get liquid drops on the stationary phase and in this way "multiinjections". Also the injection amount/ volume and the compatibility of solvent mixture and stationary ph. is important.
Try to control this values.
rgds
Bernd Mischke
