usp calculation
Posted: Sun Nov 18, 2007 2:14 pm
Hi, I am doing a test for the calculation of Lidocaine according to the USP. Part of the calculation states Ru/Rs where Ru and Rs is the ratio of the peak area of the standard and sample. There is internal standard in both the standard and sample. Should I take the ratio of the active to internal standard in both the standard and sample and then take the ratio of the areas, or is it just the ratio of the active peaks it means in both the standard and sample.
Thanks Liv
Thanks Liv
