Appropriate concentrations for DB-5ms columns?!
Posted: Fri Nov 16, 2007 10:04 am
by Roehrs
is somebody working with a DB-5ms column (30m, 0.25mm, 0.5um) and has a tip for a appropiate concentration for the samples? Im analysing aromatic compounds (cresol/xylenol/phenol) with toluene as solvent.
Thanks!
Oliver
Posted: Fri Nov 16, 2007 2:57 pm
by chromatographer1
100 mg per liter should be no problem.
Posted: Sat Nov 17, 2007 11:18 am
by Thunderbunny
Depends on your injection parameters - injection size and split ratio. Capacity for this dimension column is approx 200-250ng
Posted: Mon Nov 19, 2007 7:31 am
by Roehrs
I`m injecting 1 ul and using the spitless mode.
Posted: Mon Nov 19, 2007 1:30 pm
by chromatographer1
Oh my, then 100mg/liter is much too concentrated.
Less than 0.1mg per liter is a better working concentration.
best wishes,
