Hi everyone
I have a 3800GC coupled with MS4000: our problem is an extremely variation in IS area during analytical batch.
We are analysing PAH with large volume injection, in dichloromethane, with db-5ms 30m*0.25*0.25: the same method on another instrument (MS320 triple quad) is working well.
The field engineer told me that septum we are using is wrong: 1079 inj need 11,5 mm septum, not 11mm.
Is it possible that problem comes from the septa? The pressure in the injector was ok, no air or water leak.
Thanks to all.
Bye
