pK’s application in similar compound’s separation
Posted: Fri Nov 09, 2007 4:12 pm
Continue from the same topic posted on Mar 25,2006(in page 33 now)
Based on (1):
B + H <-> BH
And (2):
B•H/BH=K
We can get a general equation (3):
Tr = (Tb•K+Tbh•H)/(K+H)
Where:
Tb is theoretical parameter, base (B) retention
Tbh is BH retention
Change equation (3) to (4):
Tb•K+Tbh•H-Tr•K=Tr•H
This is the calculation and regression equation from known Tr and pH by testing the compound in three or more different pH mobile phases. Then we’ll know Tb, Tbh and pK (from K).
Then we can calculate out the compound’s retention (Tr) in any pH of mobile phase by equation (3) and plot out the “pH—Tr “curve that just like a titration curve.
If two compounds their Tbs are almost the same and their Tbhs are almost the same, too, you can find out the maximum separation in certain pH. You can also put more compounds together to find the best separation.
All above if you can use Excel, it’s not only simple and even enjoyable.
Mobile phase is simple. Different pH buffers add the same ratio of organic to adjust the Tr in an acceptable range for tested pHs, that’s all.
I hope I can discuss with interested people. If you need my Excel spread sheet for your references, I can give you.
If you have any questions, you are welcome to post it and discuss it.
Based on (1):
B + H <-> BH
And (2):
B•H/BH=K
Where:
Tbh is BH retention
