column brand difference??
Posted: Thu Nov 08, 2007 6:16 am
Hi
We have a method for determination of impurities using RP-HPLC, previously we used grace vydac C18 column,4.6 X 250mm ,300A and had 3 related, well resolved impurities
Recently we shifted it to a different brand of column with same column specification (in this case “ACE-C18 4.6 X 250mm ,300A) after this change we found that the number of impurities resolved were much higher than pervious column.i.e we have 7 related well resolved impurities in comparison with old column which had 3 impurities.
I would like to know what is the reason for such an observation..any one else have same experience??..one of my colleague told me that the purity of silica may be the reason behind such a change..is it true..? if so how do I investigate it..? (I would like to know do you look into specification such as purity of silica when choosing a column?if so how??)
Thank you
Thank you
