signal to noise ratio?
Posted: Mon Oct 29, 2007 6:16 pm
by zimanli
HOw to get signal to noise ratio and resolution between two peaks using Chemstation for Agilent 1100?
thanks
Posted: Mon Oct 29, 2007 9:32 pm
by zokitano
zimanli,
When you're creating report in Data Analysis go to the menu bar Report/Specify Report and then choose the type of the report: Performance + Noise (if you want to have the noise in your report with resolution etc)
Hope this helps
Posted: Tue Oct 30, 2007 2:07 am
by zimanli
thanks
have a nice day
Posted: Tue Oct 30, 2007 1:06 pm
by zimanli
I have signal/noise column, but it is all - without numbers.
DO I need to set any parameters to get signal to noise ratio for each peak?
thanks
Posted: Tue Oct 30, 2007 1:56 pm
by zokitano
Ok, I forgot to tell you to follow the entire procedure when you're creating a new method...
Anyway, in order to obtain your S/N values in the report you'll have to do the following:
1)In Method and Run Control click on the Menu bar Method
2)From the fall-down menu select Edit Entire Method
3)Input your method parameters (if you haven't done it already) for flow, injector, column compartment, signal...
4)When you'll get to the parameter: Specify Report in the window select the Report Style to be Performance+Noise and click OK to close the window
5)At the end of the method editing you'll come to a box that specifies the parameter Signal to Noise. Enter the time windows in which you want S/N to be measured by the software.
6)At the end save the method and run your analyses
7)If you want to change the time windows for S/N measuring during the optimization of your method just start the procedure from 1) and follow the instructions.
In your report you'll get the numbers for S/N for the specified time window(s) that you have already set in the method.
I hope this helps
Good luck
