Split ratio problem. Help!
Posted: Thu Oct 25, 2007 1:09 am
Hi! I'm doing separations using a Shimadzu 17A GC, using a TC-1 column 0.25 mm i.d. x 30 m. I have been working with split ratios of 10:1, 5:1, 3:1, since my compounds are in very small concentrations. However, the problem is, recently the machine can't achieve such split ratios, I'm getting 100:1, 60:1, 30:1, too high for the samples I have, and I'm not getting any peaks. Does anybody have an idea of what's going on with the machine? Why I'm not being able to reach the split ratios I want?, even when I set the machine to 10:1, it quickly goes to 50:1 or higher.
Help please!
Help please!
