Z-Spray vs Turbo V
Posted: Tue Oct 23, 2007 11:54 pm
by yangz00g
Theroetcially, Tubo V 's orthogonal design is better than Z-Spary if there is no the heater? Cross-flow nebulization has been around for many years, but mostly used in ICP source. No doubt that a cross-flow neb is better than a pneumatic one (most used in ESI). If Z-spray also has heated nub gas, it may be better than Tubo V according to its design? curious.
Posted: Thu Oct 25, 2007 10:46 pm
by giacomo56
Unfortunately all Vendors claim their design is the best !!!!, but, in an honest discussion an orthogonal design with one bend should theoretically be the best...counter-current drying gas should desolvate more effectively then gas being employed at a 45 degree (V Turbo-Source) and making two bends to get an ion into the MassSpec would lag behind(Z-Spray).....the simpler the better.....then you have the Off-Axis design employed by two other vendors, because they could NOT find a way around the Orthogonal patent....which by the way was introduced by Agilent, and soon copied, my 2cents... :)
Posted: Mon Oct 29, 2007 8:09 pm
by yangz00g
yes, it's always a pain to clean the Z-spray source.
