ChemStation: Load new method and sequence at startup
Posted: Thu Sep 09, 2004 2:24 pm
Either I haven't looked hard enough (possible), or it isn't straight forward (more likely), but does anyone know how to setup USER.MAC to load a new method and sequence when ChemStation starts, so all the parameters are reset?
I know that I could just load up def_lc.m and def_lc.s, but the problem we have is that the ChemStation may not be defaulted to the correct local method and sequence subdirectories (we also save sequences on network drives if they need to be moved and load methods from a network drive which are saved locally, but often in the wrong folder).
Tim
Tim
