Elementary Ion Chromatography
Posted: Sat Oct 20, 2007 4:55 am
Hi All--
Can someone suggest a good resource for learning basic ion chromatography? I have a strong background in HPLC but am feeling a little lost with our IC system. I am trying to develop a separation using a suppressed anion system.
My starting point is an application note that uses a 3.2 mM carbonate/1.0 mM bicarbonate mobile phase. I've tried adjusting these ratios as one might with an HPLC mobile phase composition, but I don't see much happening to improve my resolution.
Can someone explain how the CO3/HCO3 system works to elute the analyte ions? Is one considered the strong solvent and the other the weak solvent?
