Theoretical Plate Method Validation
Posted: Wed Oct 17, 2007 8:21 pm
I am required to validate the test method of determining the height equivalent theoretical plates unless I am using a compendial method. Is anyone aware of a compendial source for determining HETP? Most sources, i.e. USP just give the equations and don't go into detail about how to perform the method. If I have to validate, what kind of repeatability should I expect from measuring HETP on the same column on multiple days? Thanks for your help!
